Hey I was looking for an f23 block to swap my f22a1 head on(I am boosting my motor and I don't wan't to boost with 210000 miles already on the block.). anyways, I came across a full f23a1 for about 300 dollars. My question is, is the vtec for the f23a1 performance vtec? or just economy vtec? also, would I be better off swapping the motor as a whole(keep in mind it is OBD2 and I would have to wire for vtec etc.) or swapping my head onto it and utilize the extra displacement and lower CR for boost?
Question about f23a1
Originally posted by 14bcb7 View PostHey I was looking for an f23 block to swap my f22a1 head on(I am boosting my motor and I don't wan't to boost with 210000 miles already on the block.). anyways, I came across a full f23a1 for about 300 dollars. My question is, is the vtec for the f23a1 performance vtec? or just economy vtec? also, would I be better off swapping the motor as a whole(keep in mind it is OBD2 and I would have to wire for vtec etc.) or swapping my head onto it and utilize the extra displacement and lower CR for boost?
That is indeed an economy VTEC. Heres the H and F series compression ratio calculator. http://www.zealautowerks.com/hfseries.html
f23 block with f22 head has been done I believe...though the person that did it refused to share even the slightest amount of info...dah well...they aren't obligated to...point being you won't find a good diy or how to for it.
start with head gasket comparison...go from there. I wouldn't bother with the f23 head...go with f22 head and f23 block.
The f22 head does flow better and has better potential imo
Will it work...who knows...you'll have to do a LOT of measuring and research. Maybe...just maybe...once you've done the research to see HOW likely it is, those that have done it will help you out via pm's and such...I'm not one of 'em just saying.
there's a lot of talk and no action when it comes to this.
*edit
nice site...coolness
This calculator is intended for use as a general estimate of your compression only. Not all values are verified.____
Originally posted by BLUBB2 View PostThat is indeed an economy VTEC. Heres the H and F series compression ratio calculator. http://www.zealautowerks.com/hfseries.html
Originally posted by bcjammerx View Postf23 block with f22 head has been done I believe...though the person that did it refused to share even the slightest amount of info...dah well...they aren't obligated to...point being you won't find a good diy or how to for it.
*edit
As much as I support the use of the F22A head... if I were in this position, I would choose the full F23A1 and boost it. Even though the F22A head flows better, the F23A1 will make plenty of power with boost, and you won't have to be concerned with the potential reliability issues associated with a headswap AND turbo.
Since you'll be going turbo, you'll have to convert the F23A1 to OBD1 for tuning anyway.
Originally posted by deevergote View PostAs much as I support the use of the F22A head... if I were in this position, I would choose the full F23A1 and boost it. Even though the F22A head flows better, the F23A1 will make plenty of power with boost, and you won't have to be concerned with the potential reliability issues associated with a headswap AND turbo.
Ok. Update. I realized the f23a1 exhaust ports look like this O--OO--O as opposed to O-O-O-O for the f22a1. Although it would love to swap the whole f23a1, I am going to be running a DSM setup and the manifold wont work the the f23a1. So unless anyone knows of a DSM manifold that will work for the f23a1 (or f22b1 for that matter), I guess I'm going f22a1 head on the f23a1 block. Question, will I have to bore out the head to match?
You won't have to... but it might be a good idea.
DSM manifolds came on DSMs. With 4G63 engines. With 0_0_0_0 port layouts.
There are manifolds available for the F22B1 and F23A1 that you can buy. It would probably be far more reliable to boost a complete engine, and not take your chances building a frankenstein motor for use with turbo. Some have done it successfully... others have failed miserably.
*edit
right on man, I am doing this same build (once my wallet catches up with my plans that is!)
F23a motors came vtec and non vtec.
F23a1/4 are vtec and rated at 9.3:1. and like F22a90 stated, all you have to do it plug up that oil control orifice.
F23a5 is non vtec so you may be leaning towards this block right now since there is no hole you have to plug...but it only yields a CR of 8.8:1.
Although theoretically the lower the CR the safer...9.3:1 won't blow anything up if you know how to tune and will definitely give you an increase in power.
A while back a member on here was running an f23a1/4 block with an f22a6 head N/A and loved the increase in CR, power, and displacement.
All hail the F Franks!!!!!!
GLWB holmes
Andy
^^click it or ticket^^
wow first off i have to say the noob has some experience to him/\/\.he beat me to the punch.
also u will have to use the f22 harness so it will stay obd1.and when u swap the head use the f22 intake mani too it will save u some problems wire wise.and use ur f22 ecu unless u have a chipped ecu ready for a tune.
/\/\ this guy explained it in a nut shell really theres nuthin else to kno.
