Wheel bearing/Hub
    Wheel bearing/Hub
    Hey Guys,
    I'm doing a break job and took off the hub/wheel bearing assembly. When i rotate the bearing, I don't hear any noise, but there is play in the bearing when I tilt it up and down (side to side).
    Is my wheel bearing bad? Should there be absolutely no play at all?
    Thanks,
    Originally posted by KINGPIN33 View Post
    Hey Guys,
    Thanks,
    I believe that if there is that amount of play it indicates considerable wear and you should install a new bearing. Normally they are kind of "tight" and, for example, won't spin freely under just finger pressure. But perhaps wait for others to respond.
    I recently had my rear hub and bearing in hand and I don't recall that there was play at all in any direction, and it was smooth but did not spin "freely", in other words you could turn it smoothly but it stopped turning immediately if you tried to spin it and remove your hand.
    I could be wrong but that's my take on it.
      Replace it. I just did my front rotors and mine were tight, no play, and smooth moving.
      90 Panda DX F22A6
        yea double roller ball bearing should not have any play.
          Thanks for the response guys.
          I'm going to take the rotor/hub/wheel bearing assembly to the shop to replace everything (inc. rotor and bearing). I can't for the life of me get the hub cap off to take the rotor off!
            rotor and hub comes off the spindle as one. there's four 6 or 12pt bolts on the back of the spindle. then you'll need to beat it out or use a slide hammer.
            when you get it off, the four 14mm bolts that were facing you ont he hub is what holds the rotor and hub together.
              The Haynes manual says you need to press the hub/bearing assembly onto the steering knuckle. Is this incorrect? I've got some Timken hub/bearings I need to put on, and since my CB's currently not drivable (rear-ended an Escape... took out some major front-end parts), I figure I may as well do it myself if it's just a bolt-on.
              Accord Aero-R
                only the bearing needs to be pressed onto the hub.
                  This just bolts on, then?
                  Accord Aero-R
                    correctamundo. walk it in with the bolts in a criss cross pattern though so you dont get it all cock-eyed.
                      Thanks, I thought I was going to have to pay a shop to press it on for me
                      Accord Aero-R
