grinding noise
    grinding noise
    whats goin on i jus bought a cb7 4dr and the drivers side wheel sounds like its grinding or binding or somethin...but the car still drives str8...jus a loud annoying grinding...probably gonna replace the whole front drivers side assembly....any ideas b4 i do that...was also thinkin that it might be a wheel bearing
    I had a 95 accord same problem, turns out the wheel hub bearing was bad. you should check that out.
    btw, its not really smart to post like 60 times in a row like that
      I had the same problem. Drove with it like that for about 6 months or so before getting it fixed. It was my front hub bearings. Definately need to get it repaired though.
      My 2004 Subaru Impreza WRX Thread
        Wheel bearing or brakes.
        As for your thoroughly inconsiderate incessant bumping of your thread... THAT is why nobody has bothered helping you. It's also why your post count has been returned to 0. Please follow the rules of this forum.
          Does it make the grinding noise all the time or only when you hit the brakes or when you are turning?
