f22A6 intake manifold
    I have F22A1 motor in my car. I was wondering if I put the A6 intake manifold do I need the A6 ECU? tnkx 4ur time
    yes. the pt3 (a1 ecu) cannot compensate for the extra air flow. the pt6 (a6 ecu) can.
    90 LX (R.I.P.) http://www.cb7tuner.com/vbb/showthread.php?t=137301
    91 EX (DD) http://www.cb7tuner.com/vbb/showthread.php?t=142483
      That is not the reason you would want a PT6. The main reason you would want a PT6 over a PT3 with a F22A6 intake manifold is for the IAB's. The PT6 activates the secondary runners. It really has nothing to do with compensating for the extra air flow because I'm pretty sure the ECU would do this automatically based on the O2 sensor reading.
      PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
      Listen or download the first 4 songs I completed for my new upcoming album here!!
      My member's ride
        it does. BUT the pt3 isn't tuned for the more fuel needed on the top end. yes the o2 does compensate but it can only do so much. I was just running the pt3 with the a6 manifold and it lagged on the top end. i switched to the pt6 and it was a noticeable difference.
          The reason it lagged on the top end was because the secondary runners were not activating with the PT3. When you installed the PT6, the secondaries activated.
          My member's ride
            If they are unhook then they are open all the time, if they are hook with straight vac. from the mani they will be fully open a WOT. You can get a P12 and really wake your car up.
            "The Turtle"
            DD/Trail Rig/Mud Bug
              Do you have the spacer gutted or are the butterflies still in it?
                Did you throw the A6 cam in as well?
                "The Turtle"
                  OK that makes no sense to me...
                  You said..."If they are unhook then they are open all the time"
                  ...meaning if you disconnnect the line the flaps are always OPEN?...that doesnt sound right...the vacuum line draws air IN I thought, OPENING the flaps? CORRECT?
                  "...if they are hook with straight vac. from the mani they will be fully open a WOT."
                  So if you disconnect the line, its wide open.... if you connect it to a vacuum line, its wide open....????
                  Also how can a P12 "wake up" a car that already uses the IAB with the PT6?
                  * owe my head *
                  Please SOMEONE clarify....
                    The butterflies are on a spring. When vacuum is present it holds the butterflies closed. When your car is off, the butterflies are open. As soon as you start your car up, vacuum builds and the butterflies close. As you increase throttle, there is less vacuum present so the butterflies open. Get it?
                    The P12 would not be the optimal setup for a car that has a A6 manifold because it does not control the IAB's. I have a P12 in my car and yes it does give it a little more power, but I would not say it "really wakes my car up".
                    My member's ride
                      Yeah I couldn't think of another way to say it really. But he at least if he is running the PT6 he needs the A6 cam. I know someone running a P12 on an A6 but I have not really asked him how it's compared to the PT6.
                      Ok to clearfiy my before statement that they are open all the time if not hook up. The spring holds them open, when you start the car up the vac closes them with the use of the iab diaphram. When it is connected to the mani it basically open the same amount as the tb does to a certain extant.
                      Also if you don't belive any of this go get some vac plugs and try it yourself. Thats exactly what I did.
                      "The Turtle"
                        no. this is not what happened as the secondaries are hooked up to the intake manifold vac. not the black box. the lag was more than running the A1 single runner manifold.
                        the butterflies are in it
                        i have a fully built f22. bored, higher CR, etc. its not like i don't know what i'm talking about guys.
                          Ment that to go to the op, not you. Also just because you have a built F22 doesn't also mean you know what you are talking about, just saying not saying you don't know though.
                          "The Turtle"
                            very true. i just figure don't post unless you know what you're talking about. isn't that the point of this board? to share correct information or at the least personal experience?
                            sorry to the OP for
                              sorry to the OP for
                              Yes, but there are a few people who think they know what they are talking about but don't.
                              "The Turtle"
