93 LX is wandering toward the right. Bad struts or springs??
    Hey there,
    I have a 93 lx and ive been having some issues lately with the car wandering toward the right at highway speeds. I know the struts and springs are worn because they are more than likely the originals. the left side of the car also seems to sit lower. Should i replace the struts/springs or could i be having a camber issue? if yes on the struts and springs, what are some suggestions for decent equipment at a decent price?
    Thanks!
    Have you had your car aligned?
      the car has four new tires on it, and has been aligned. its also got brand new rotors and pads on the front but the steering wheel wobbles when breaking from highway speeds. It's like something isnt seated properly.
        If it "wobbles" when braking, you may have warped rotors.
          hmmm check out the
          tire pressure
          shocks/ springs
          alignment
          lovin every minute of it
            I had warped rotors about a month ago. I got the rotors pads and brake lines all replaced, which is why i think it might be a suspension issue
              Well, then get new suspension. Even if it doesn't fix the issue, at least it'll look better.
                yea definitely. Any suggestions on which struts/springs to look at? not really familiar with suspension stuff
                  ^^ that made me laughh but ya sounds like new suspension, probably shot and blown, replace, slammage post pics
                    yea i had my car airbourne once. It wasnt on purpose and scared the crap out of me but i think the landing finally did my front drivers side strut in.
                      Suggestions on spring/strut setups?
                        How low you wanna go?
                          well how much are you willing to pay? it all depends on your funds
                            not too ridiculously low, and ive got maybe 400 ish to spend. remember im only replacing the front pair right now. will probably do the back later, but they seem fine now.
                              check bushings, and ball joints. Being lowered like you puts alot of stress on them. Also did you break your brakes in correctly? Brake vibrations are usually (and especially after replacing) due to impropper break in. We used to have alot of issues with this with i was an audi tech where people would come in a week after having brakes done and saying their brakes were shaking at highway speeds. We usually would just go around the block and do a 30 30 30. thats thirty stops from 30 miles an hour in 30 feet each. This puts the brakes through the propper heat cycle needed to seat the pads properly and eliminate brake shimmy.
                              member ride thread
                              DIVULGE MOTORSPORTS
