sometimes my car doesnt seem to start but after a min or two it will start..this only occurs if the car sits in the sun for a very long time or sometimes when i shut the engine off and start it again...im not sure but im thinking its the main relay..can anyone help me out here?
starting problem...
It's most likely the main relay. You should take it out and open it up and just re-solder the contacts. While you have it open, drill some holes in the plastic case to allow the relay to vent better. I took mine a step further and drilled holes in the plastic case and even put a small computer fan attached to it. I have never had a problem since.
You said it happens if the car is sitting in the sun for a while. What happens is the change in temperatures makes the contacts expand and contract and they lose connection.Last edited by AbsurdNY; 09-21-2009, 08:48 AM.
