Random Automatic Revving When Idling
    Yes my CB9 randomly revs at idling at times by it self. I have no mods done other than regular maintenance on the car. After a while it goes away (I'm thinking it needs to warm up) and usually happens after I rev it then repeats it by itself.
    I haven't tested this in a while.
    Current:
    2007 Acura TL Type-S 6MT KBP
    Past:
    1992 Honda Accord EX-R Sedan - RIP
    1991 Honda Accord EX-R Wagon - RIP 10/14/2010
    Words change lives. You just got to choose the right ones.
    Instagram: @CB7Nub
    Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
    does it do this as soon as your done starting it?
      Seems like you have a Fast Idle Valve problem... or something like that.
      ...bleh, to lazy to describe, so just follow the link:
      http://www.honda-tech.com/showthread.php?t=1564019
      Either do that or replace it/delete it.
      Accord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
      Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
        Mine does this exact same thing and it's damn annoying.
        Thanks shadowdlink, I'm gunna try cleaning the FIV. I suggest you do too CB7Nub.
        Member's Ride Thread
        Originally posted by mercyboy
        I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
          Thanks for the link Shadowdlink, helped a lot.
          Current:
          Past:
          Instagram: @CB7Nub
            Throttle body cleaner is your friend. While you're at it you could go ahead and do the other valves on your intake manifold if you have the time. Just a thought.
              Have you checked your coolant? Air in the system can cause this problem as well.
                I had this same problem as I said earlier. Just removed the FIV, and boom. Solved.
