not sure what it is b/c brakes were just replaced. could be rotors but not sure either. when ever i try to stop or slow down the car shakes violently when i press the brake and it takes alittle longer to stop the car. feels like the brakes or rotor aren't working right. if any one knows whats wrong please help. i know its somthing i could fix my self just need to find out what it is.
car shakes violently when braking
did u pay to have the brakes replaced? or did you do them, if u payed Take it back, if not is the shake in the steering wheel? or more in the pedal/seat. to determine front or rear. but 9/10 times it is the front rotors that warp before the rear. u can see if a shop has an on car brake lath. if they can be cut or you could get new rotors
was it shaking before u changed the pads?
more than likley its warped rotors.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Very likely warped rotors.
However, when you replaced your pads, since you did it yourself, I'm assuming that you didn't have the rotors resurfaced. Did you at least scuff them up really well with sandpaper? Then did you break in the pads correctly?
If you just slapped on the pads and went about your business as if nothing had changed (no break in), then you're probably experiencing the effects of glazed pads and rotors. Basically... now those pads are shot too.
