buckys idle problem
    buckys idle problem
    i just rebuilt my motor and im at 25 miles on it now.. and ive been noticing im getting a check engine light once i start driving.. and when i sit at a stop sign or red light my car will idle from 600RPm to 800RPm.. could anyone diagnose these problem for me please?.. if you need more information just let me know
    much appreciated,
    bucky
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    no one can help me
      but i mean the car run perfect other than that idle every so often and the annoying light
        I had that issue with mine before and I had the TB cleaned out and it was fine.
        That or a vacuum leak?
        Its just me
          You need to pull the code(s)
            i thought that only worked if your check engine light came on as soon as you turn the car on...
              The codes are recorded in the computer, even if the light isn't on, the code should still be available, unless you reset the ECU. I had this problem, in fact I'm having it again.
              Last fix was the Primary O2 sensor. I don't remember exactly what code that was, but it completely went away. It can be a vacuum leak, had that issue also, but those are a little harder to diagnose, because they can be in so many places.
              Try pulling the code, and post it up. I'm sure people will be able to help with that info once its up, or you can always do a search for it.
