help on turbo decision on h22a
    i have a jdm h22a i would like to do a bolt on turbo kit.and i heard that u can do eclipse turbo oem? also my block will handle the turbo kit ? thank for u help
    You can handle around 8 PSI safely without touching anything inside the motor. I know that DSM turbos and injectors work good on F22's but I'm not too sure how they are on H22's.
    PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
    Listen or download the first 4 songs I completed for my new upcoming album here!!
    My member's ride
      it's not so much a psi issue but a horsepower concern. used h22's id beware of the rod bearings and wear on the cylinders.
        The DSM parts are mainly only good for the F22A. The H22A should have a bit more money put into it if you want it to be reliable. The H22A's compression is a good deal higher than the F22A's, which means tuning and properly sized parts are much more important.
          ^what he said. Its not hp or psi thats a problem with tc an h22 its the high ass compression. As for picking the right turbo there are alot of good sites to help find the right size. There are many t3/t4s that will be fine for ur app.
            You can run H22's on boost...You just have to know what your doing.
