im new to the honda thing so yea i guess i am a noob.....im more of a muscle car person.....got a 01 sierra i drive cuz this dang car broke...but i wana fix this punk thing up... we checkd for the spark and it do got it.....it aint the gas cuz we put sum gas in injectors and it still wouldnt start.... what u think it is now.
I dont know whats wrong with my car
Originally posted by greatestmexican View Postim new to the honda thing so yea i guess i am a noob.....im more of a muscle car person.....got a 01 sierra i drive cuz this dang car broke...but i wana fix this punk thing up... we checkd for the spark and it do got it.....it aint the gas cuz we put sum gas in injectors and it still wouldnt start.... what u think it is now.
assuming that you definitely are not getting fuel then your next step is probably going to be the main relay. it controls the fuel pump. get a new/junkyard relay or read up on the DIY's to repair it yourself.
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
Originally posted by MR.PHIL View Posttry spraying some brake cleaner through the throttle body as someone try to crank it up .
And, exactly what do you mean when you say; "we put sum gas in injectors"??? The only way to do this is via the fuel rail via the fuel pump with the required fuel pressure...Regards from Oz,
John.
Originally posted by johnl View PostOr better still, spray some ether based spray such as 'Airostart' into the TB as you crank it over. If it fires up then you know you have a good enough spark, and the problem must therefore be fuel.
without doing a pressure test or at least cracking a line and seeing fuel spray allover (not a reliable method in terms of measured pressure, but a good indicator) you really cant tell if the motor is getting fuel via the injectors.
methinks some reading up on basic vehicle diagnostics needs to be done.
There's a number of spray hydrocarbons that might ignite if sprayed into the the engine, I know from experience that WD40 can be used at a pinch. My point was that a product such as Airostart is intended for this purpose and more likely to work because it's a lot more volatile.Regards from Oz,
John.
