Rebuling. few Honda "?"s
    well few "?" i have really didn't come up with any info from searching. so when i change the head gasket do these motors have torq-to-yield bolts? (can only be torqued once then you need new ones) then do u need a puller to remove the crank pulley or is it pop on and off? i come from a Chevrolet dealer, and im referring to there motors. and i have all of my parts coming but i want to have everything set up and planed so i can get it done Asap also for the ones that have rebuilt or re ringed the f22a anything i should look out for? any problems you ran into?
    The head bolts are not torque to yield, you are safe to re-use them. The crank pulley is also slip-fit, no need for a puller unless it's stuck due to corrosion.
      ive stripped headbolts before, thats not fun but they are only a bitch if they get overheated real bad.
      recommend reconditioning the rods because hondas like to throw rod bearings.
      oil pump: inspect or replace but inspect first because they arent cheap
      upon assembly: make the valve lash tight
      -torque oil pan and valve cover bolts/nuts to around 6 ft-lbs and not the 8-10 like the manual says.
        recondition the rods? like send them out? or new bearing (i am putting ne rod bearings in) oil pump what should i look at/for.
        i just put a header on and went opened the hood today and found what cylinders burning the oil. number 1,3,and 4 are blueing already. but little ol 2 has yet to really change
          so another thing guys. i did a compression test 2 times, the first time i got the reading from the 3rd pump and the second time threw i check peak compression and this is what i found.
          #1 183psi peak 214psi
          #2 150psi peak 173psi
          #3 185psi peak 211psi
          #4 180psi peak 212psi
          so i got low compression on number 2 and that plug was black so now we wait for rings and seals
            looks like that maybe a valve didn't seat right in #2 cylinder !! that is the first thing that comes to mind...
            also ... you can put a capful of tranny oil in the #2 cylinder and see if the compression comes up .. and if it does then its in the head and if it don't then it has something to do with the rings. !!
            Originally posted by Devergote
            A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
              Originally posted by tn_accords View Post
              l
              Wouldn't it be the opposite?
                haha yea it would be. and by the looks of the oil on the spark plug i think i already did that
                  maybe .. tired !!
                    go to sleep jacob... lol
                    if u add a lubricant to the cylinder.. and compression rises.. that means theres too much clearance between the rings/cylinder wall.. aka blowby..
                    raised compression means ur rings are worn out..
                    Praise The Lowered...
