ac help!!
    ac help!!
    my ac makes a crecching noise when i turn it on and i step on the gas...
    check your belt tension, if thats ok make sure the compressor didn't sieze.
      yeah probably because right now when i turn on the ac the condensor doesnt seem to run anymore...is there a ny way to check if its loose or not??
        the condensor is in the front of the car...? it doesn't do any "running". if its loose, its not bolted down properly...
          okay thanks ill check that...awhile back my belt started to be loose too thats probably why..,is it possible for the belt to break
