Brembo "blanks"
    Wow... I lucked out with mine then! Maybe the price of metal going up has made rotors more expensive. I suppose that would make sense...
      hi guys i have been looking at this thread and had a questions in mind.
      i would like to ask it here rather than start a new thread
      how do i know that my rotors are done?
        theres a tool you use to measure the remaining "thickness" of the rotor and it doesn't meet DOT requirements, the surface of the rotor is really chewed up, when i say chewed up it looks like the surface of an old vinyl record.
        you can take them off and take them to a shop to have them turn them and they will tell you if they are far too gone to use them anymore.
        as for warped rotors, i haven't seen that problem before so i can't tell you how it feels when you're driving.
          thanks for the reply,
          right now my situation is that my rotors are done on the honda and the car is sitting outside in the streets.
          i dont drive the car that much only once once a week or two (pleasure ride). i keep my daily in the garage because i depend on it to go to work.
          im afraid if i get new rotors it will rust up like my now ones due to not driving it much.
          but if i dont get new ones, i wont have it when i want to drive.
          idk what to do.
            look up the minimum thickness and measure that w/ a caliper. For my Acura Vigor brakes its 21mm, same as the prelude VTEC setup.
            Brembos are good though, I've had mine on for about 20k miles since April 08' Paired them up w/ Hawk HPS pads and SS lines. I got them at this place called www.importrp.com for only 40 bucks a piece. They're more expensive now, probably due to the economy (58 a piece) for brembo blanks. They do have other ones that cost about 30 a piece, but I'd highly recommend Brembo for rotors. Mine aren't even warped at all and I occasionally stop from 100+mph speeds. That could be due to the pad material though...Hawk pads are WAY better than OEM pads in stopping, they don't fade nearly as easily.
            I just checked and for Brembo blanks, they're 36 a piece for CB7s, not a bad price
              idk what to do.
              it's only surface rust...it wont hurt nothing. you want to get a good set so that if they ever do warp, just bring it to a shop that has an on car lathe and they'll resurface them on car.
