Brembo "blanks"
    Brembo "blanks"
    now when you guys say "blanks", those are just the OE spec rotors correct?
    They normally come in a red box?
    i really wanted to mate my EBC pads to their rotors BUT no one seems to have any in stock within the US currently and i don't feel comfortable forking out 150 bucks for slotted or dimpled ones.
    So Brembo is next on my list.
    they are great!
    yup OE spec but i believe it a lot better than OE. It doesn't easily warp like OEM and Aftermarket
      thanks for the quick reply.
        Whos that in the video??
        SwaggerJacker
          Hyo-ri Lee, she's a Korean pop singer
            check on honda-tech.com sponsor market forums. they might have good deals on rotor and pad
              yes check, I know that if you go or call were they honda-tech tells you to and mention them, you will get a good deal.
              does anyone have the website or link were I can get brembo blanks- reason why I am asking is that I want them for a different car (not honda)
              Originally posted by visualpoet
              some owners think it's the best thing since titties
                http://www.usautoparts.net/catalog/?...63718+9495+832
                i just ordered some Brembo blanks for a '98 Acura CL from these guys.. 92 bucks shipped to my door. that's the cheapest i've seen Brembos for.
                  wow, is that for all four corners or just a pair?
                    NAPA sells Brembos now.....
                    what car? i'll look it up.....
                      I've seen Brembo blanks for $50 a pair. CB rotors, though... CL rotors may cost more. The price you pay for ROH convenience!
                      I'm not a fan of EBC pads. My 86 hatchback has brand new Brembo rotors in the front, and a brand new EBC Green Stuff pad fell apart and pretty much destroyed one of them. The pad material fell off and it was metal on metal.
                        What car? i'll look it up.....
                        Its an 03 mach 1.
                        From the link Leung gave me they are around $63 or so for the fronts and $34ish for the rear.
                        If you can find me any cheaper ones I'd appreciate it.
                        I don't want to pay $550 for slotted rotors all around just yet,
                        and I do not want to get ripped off by a Ford dealership, if what they are going to give me is Brembo brakes which I can find cheaper.
                          hmm that sucks. did you warranty them out? i've heard nothing but good things about EBC brake pads that's why i chose them over the other brands and OE spec.
                            Ive debated getting some Brembo Blanks, but was looking for reviews. Some said im better off spending money on OEM rotors, others say theyre crappy, some say theyre wonderful. Price isnt so much an issue with me as it is, experience and issues.
                            Originally posted by Jarrett
                              Car: 1997 Honda Accord EX-V6
                              Chassis: CE6
                              I had problems with brake fade and heat damage on OE rotors and at the time could not afford anything more expensive than the cheapest rotors NAPA had to offer. The NAPA cheapos lasted less than two years (May '06 to March '08). The cheapo NAPA rotors where so heat damaged the surface formed 0.5mm wide cracks. In March '08, I finally purchased Brembo blanks and by Jan '09 I was already resurfacing them, but that was a result of driving back from Orlando with the Cruise Control set to 115mph and braking for traffic periodically; i.e. I was slowing from 115mph to 60mph repeatedly. Now it's Sep '09, I am still on the same Brembo blanks from March '08 (resurfaced in Jan '09), but they need to be resurfaced again. It isn't as bad as after my Orlando trip, but I'm starting to get the "steering wheel 'palsy" again. Keep in mind that I am really hard on my brakes (drives my wife nuts) and my EX-V6 tips the scales at 4,220 lbs; whereas your CB only weights 2,734 lbs (5-spd) or 2,800 lbs (auto).
                              At this point, I am thinking of Brembo Slotted Rotors* or driving slower.
                              * I spoke with Brad in the Brembo Performance Division shortly after '07 SEMA. He suggested Brembo slotted rotors for my situation: CE6, excessive heat damage, etc. Brad did admit that the slotted rotors would "chew" through my brake pads at a rate markedly greater than the Brembo blanks. Back in '08, that information played a big role in my choosing the blanks over the slotted rotors.
                              And I only weight 180 lbs (6'0") so my braking whoas are not 'cause of a heavy driver.
                              1997 Honda Accord EX-V6:
                              Originally posted by James Matteu
                              You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
