Better Mpg
    Better Mpg
    What are some mods that can be done to raise gas mileage?
    http://www.cb7tuner.com/vbb/showthread.php?t=130874
    http://www.cb7tuner.com/vbb/showthread.php?t=128200
    http://www.cb7tuner.com/vbb/showthread.php?t=118045
      Originally posted by FAMOUS T.R.K.
      simple a turbo
      [/IMG]
      Who's car is this?
        simple a turbo
        Dammit! Beat me to it!
          are there any CA smog legal turbos for the CB?....i've never heard of one....and personally i dont think i would save much on gas if i had a turbo....i'll be having too much fun driving.
            well turbo is suppose to burn all of the gas. so no wasted gas like a N/A car.
              Probably different on a gasser, but on my cummins, the larger the turbo has gotten, the worse the mileage has been.
              But its great watching the boost guage hit 45psi..
                The way to make power with diesels is to up the boost and dump in more fuel. With a gasser, injectors aren't something you have to worry about early on in a mild build... but when I was researching diesels, I saw that injecors are often the FIRST thing you get!
                How much power are you making with 45psi? Holy crap!
                As for "smog legal turbos"... there are no CARB approved turbo kits. In fact, there are no real turbo kits available for the CB7 anymore period. It's all pieced together... or cheap crap slapped together and sold as a "kit" on ebay.
                However, if you can get by the visual inspection, a good tune can make a turbo motor emissions-friendly.
                And turbos "burn all the gas"? vietkid_2006, do you have any technical knowledge to back this up, or did that one just slip out of your colon? Turbos shouldn't burn anything.
                The hot exhaust gas spins the turbo, which sucks in fresh air, compresses it, and stuffs it into the engine. The fuel is there to control the burn of oxygen. It's the oxygen that makes the power. The fuel controls it, and helps prevent detonation. More oxygen needs more fuel.
                The exhaust, regardless of how much fuel is burned, merely spins the turbo and exits out the exhaust pipe.
                Turbos, in boost, WILL burn more gas. When not in boost, a proper tune can keep the engine running at NA efficiency.
