can i upgrade just the cylinder head??
    i have a f22a engine in my car and i was just thinking if i could put some other cylinder head to gain more power? if it is possible which head would fit my block?
    Turbo F22 Under Construction
    The stock one already has a really good design to it as far as air flow. If anything you could have someone do a port and polish on it. What other mods do you have on your engine though?
      I wouldn't recomend it. The head you have already is good. Put your cash towards a better cam shaft setup, exhaust, header, and tuning. That should keep you saving for some time.
      Past 1990 Accord EX Sedan
      Past 1990 Accord LX Sedan
      Past 1991 Accord LX Sedan
      Past 1993 Accord LX Wagon
      Current 1991 Accord EX Wagon
        i haven't done anything to the engine yet.
          i haven't done any mods in the engine
            The f22a head is among the best flowing honda heads, the exhaust ports could use some work, but apart from that, its a quality head and no headswap will net you power, you would lose some actually.
              I would start out with the basic bolt ons then. Intake, header, and exhaust would be the first things. Which F do you have?
                Have you checked into this thread ? http://www.cb7tuner.com/vbb/showthread.php?t=88154 It's at the very least a good read and if used it's an excellent first step to getting your feet wet with learning your CB7 .
                  F22A head, ported and polished.
                  Bisimoto header.
                  Bisimoto Stage 1 cam.
                  H23A1 intake manifold with the throttle body bored by Maxbore.
                  Short ram intake with an AEM Dry Flo filter.
                  Apexi World Sport 2 exhaust.
                  Those mods would make for a VERY fun car to drive, while remaining quite reliable and efficient. A P06 ECU, properly tuned (this takes considerable knowledge), would result in even more power and efficiency.
                  Headswaps are a bad idea. The SOHC VTEC heads are garbage, and the DOHC VTEC heads don't flow as well... and won't work very well with the F22A's low compression.
                    its a f22A6
