I just bought a replacement motor for me 93 Accord SE that had a f22a6 in it. I'm trying to figure out which parts i need to switch over but the code on me replacement engine just says f22a with the numbers 2007935 under it but no number after it. So my question is could it be a JDM f22a? And if it is what do I need to do to make it work with the ECU in my SE?
JDM f22a?
I'm pretty sure there is no such thing as a JDM F22A. Accords in Japan came with either a F18 or a F20 I believe.Last edited by AbsurdNY; 09-08-2009, 05:12 PM.
JDM F22A do exist you can buy them at engine importer just like an JDM H22A. The JDM F22A= to USDM F22A6 engine and should be same power rating. It usually has low millage and if in good condition, should outlast most used/junkyard/refurbished f22a1-6 engine.90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
< 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
Originally posted by deevergote View PostNo number means it's JDM. JDM motors do not have numbers... F22A only.
Essentially, it's an F22A6.
I have a JDM F22A right now. I was going to use it...but now im going H22A. haha
My dad had it at his shop for some reason. Its still a good engine, he took it out of a 4th gen to put a F22B1 in...which was a waste of time and money on the customers behalf.
but yea...its just sitting there chillin.
-Jordan
I ♥/Miss My Coupe
Originally posted by jay92889 View PostHey, I was just reading through this and had a relevant question. In my '90 Ex my engine is just stamped as an f22a. Since this indicates that it's JDM, is there a way I can check and see if the cam is an A6 cam as opposed to an A1/4? Reason I ask was that I was at the junkyard yesterday, and I was going to go back today to get an a6 cam, but this thread makes me unsure of whether I need it! I already have an a6 manifold to install, and my trip yesterday yielded a pt6! Everything but the cam.
I blew up my JDM F22a and got it replaced with a JDM H22a.
the F22a came off a JDM CB9, which had 140PS and 192Nm
Click sig to view MR thread
Links to other rides:
Honda Accord Euro-R
Honda Odyssey Absolute
Honda City I-DSi
Honda Stream
