i know its been done a hundred times but...
    i finally got my ebay pipe and plan on getting the K&N filter this week. heres a pic of the ebay kit.
    question is, what do i do and how do i do it? im searching all the posts about this topic as we speak but a lack of installation pics has me terribly confused.
    thanks in advance
    ok take a screwdriver ( doesnt matter what kind ) or 8mm i wanna say if not a 10mm and look at the end of the stock black one. u gotta loosen that bolt. then u gotta pull the other crap thats comming out of it as well ( just pull ) then u gotta open your air box ( there should be 3 lil bolts thats are the same as the one u took out close to the end going into the motor ) from there lift the oem filter then u should see more bolts under it i dont remember ( its been 6 years lol ) undo those and lift the bottom of the oem airbox. from there the rest should be bruit force.
    u wont beable to fit the cold air without cutting your frame, sooo ull be installing the S pipe put the black thing on one end with a cobra clamp then put the filter on the other and tighten those clamps. then put one more clamp on the end of the black thing so u can attach it where the oem one was. its pretty strait forward and simple if u look at one installed and they arent that hard to find on any website.
    [COLOR="Magenta"]
      i didnt really want a CAI, i just wanted the pipe. i think im just gonna use the s-pipe right? will that fit better? and what size cone should i look for. i measured the pipe and its 2.75".
        order a 2.75" K&N cone filter. It will be about 40 bucks.
        Finally Up and Running. Numbers to Follow. Check my MR
          lol id love to order it but my mom is mad enough i got this off ebay. i saw some K&Ns at autozone, i just wasnt sure about the size. but thanks, at least now i know what to look for.
            I have the same exact one except for mine is black. These are the only pics I have right now. It's raining outside or i'd go get you a couple more. You should get the idea though. The s pipe connects to the throttle body and the other one goes down beside your battery. As was mentioned before, you'll have to cut a hole by your battery so the other pipe can go through. Hope this helps.
              http://www.ehow.com/how_2190869_inst...ir-intake.html
              here goes a link 4 u
              Blood, Sweat & Tears
                so brandon, you only used the s-pipe right, and it fit okay (no major cutting or anything) because my friend may not have all those tools, just the basics to remove the airbox and get this into place
                  seriously? Dude this is pretty straight forward...
                  But one thing you'll need to do...get a K&N filter...I don't trust that ebay filter
                  ____
                    pmed
