I was looking at installing a cold air intake but since I use my car for a daily driver and its often wet here I don' t think it would be a good choice. Do you guys think its worth putting a short ram air on considering its so close to the engine? Is it worth buy an AEM over an ebay brand?
Short ram air
You're probably going to be told to search because of how much this has been discussed on here. But to answer your question, get a bypass valve if you're running a cai and that will help keep it from hydrolocking. If you know it's going to be pouring down, flood weather then just take the bottom tube off and run it as a short ram. As far as the piping goes, wether you pay 200 or 20 dollars for the intake they are both going to be a pipe. Buy the cheap one and put a quality filter on it and you'll be fine. Hope this helped.
I've been running a cold air intake since 2003 with no troubles. I just don't drive through big puddles. It's really not that hard to avoid large bodies of water in the road.
A short ram intake will be fine. When the car is moving, the air temperature isn't all that warm.
You'd be fine with a cheap no-name short ram pipe, but I would upgrade the filter to AEM or K&N. The cheap filters don't work well, costing power, and eventually damaging your engine because they don't filter properly.
You can get them from auto zone or advanced most of the time. You can probably find them cheaper online but i'm not too sure. Here's a bunch of them just to give you an idea. The last thing I read Apexi had tested the best but you really can't go wrong with any name brand filter.
http://www.thepartsbin.com/catalog/?...onda&md=Accord
Originally posted by Brandoncb7 View PostYou can get them from auto zone or advanced most of the time. You can probably find them cheaper online but i'm not too sure. Here's a bunch of them just to give you an idea. The last thing I read Apexi had tested the best but you really can't go wrong with any name brand filter.
