battery dead and cant get out of park
    so my 1992 accords battery is dead and its in the middle of the garage so i cant get another car in to boost it. I was gonna roll it down on the driveway manually by putting my key beside the shifter but it just wont get out of park when i do put my key in all the way. My question is what could it be need help fast thanks.
    i'm not quite sure why that method isn't working for you.
    are you sure you are putting the key in as far as you can while your foot is on the brake pedal? worst comes to worse, you could take the battery out and hoof it to autozone and have them check and charge it for you.
      make sure that you have you foot on brake as stated above. you could also try turning the ignition to the on position and moving the shifter then.
