removed distributer put back in, wont start
    Was trying to replace o-ring (could not locate it). took distrib off carefully, put it back in, now wont start...any tips on what i need to do?? Does it need to be retimed?? Thanks
    Did you plug everything how it was before? It looks like you might have put your spark plug wire in reverse order or incorrect order. (happen to my friend civic. open up chilton manual and follow the order. the car start up again)
      reading haynes right now. I think i check and make sure rotor is pointing to number one spark plug..not sure how this is done though
        did you mark the timing?
        when you remove it did you make a mark on the top bolt?
        you timing might be off.
        here is firing order.
        for free online Chilton manual
        http://www.cb7tuner.com/vbb/showthread.php?t=140323
          Got it!!
          Thanks guys..just started(typing lapp top w greasy fingers lol), all i did was re direct the rotor pointing it to the the number one spark plug. It must have rotated when i initially removed it...whew, am happy now, Beer time
