throttle body spacer?
    do throttle body spacers work or is it a waist of money?
    I don't see how there would be big gains as the TB isn't connected to anything hot/warm. I mean it wouldn't HURT but more gains are had by intake runners to head spacers (intake manifold gasket spacer) as the head DOES get hot.
    There have been 5hp gains when using the blacktrax spacer (plenum to runners, it is plastic not metal). But I don't think they had an intake manifold gasket spacer like what bisi sales.
    I guess plastic/teflon spacer if thick enough at the TB, plenum to runners, and runners to head could all add up...but I dunno how much total...5hp up to? just my musings
    ____
      I don't know about a waist, but it would be a waste of money. They do nothing for us. A plenum spacer, on the other hand, will.
        what do you mean by plenum spacer... sorry for the noobishism lol
          The plenum is the "tank" at the top of your intake manifold. The part that the throttle body is attached to. If you put a spacer between that and the lower part, you can gain power. Check out spacers by Blacktrax. http://www.cb7tuner.com/vbb/showthread.php?t=83042
            i bought an a6 spacer and gutted it... i think the holes are kinda cone shaped. imma take it to work so i can precisely measure it and hopefully port and polish it
              Cool...I knew the plenum spacer by blacktrax had gains...didn't think the tb would for reasons as stated
              Originally posted by rum_n_coke
              no you bought a metal IAB plate and took the butterflies out.
              The blacktrax spacer is NOT metal, that is one of the ways it keeps things cool
              ____
                Yeah, the Blacktrax spacer is better because it's a thermal plastic, and it doesn't have holes in it that create turbulence. A gutted IAB plate works to some extent, but the Blacktrax piece is better.
