need a rear engine mount
    anyone know where i can get a oem rear engine mount for my 93 accord ex. priced one at the dealer its about 250. i found one on ebay a while ago but it didnt even last 6 months. any ideas where i can get one for less than 250? any help is greatly appreciated.
    junkyard?
    峠 で ドリフト を して 下さい。
    steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
      or if you're looking for new
      http://www.hondaautomotiveparts.com
      i dont know what the price would be on there, but it's worth a look i guess
      峠 で ドリフト を して 下さい。
        its a little cheaper on there 230 shipped. also i have checked many junkyards and all the ones i have seen are torn. so junkyards are no help. thanks for the suggestion tho
          anyone else have any ideas where i can get a this mount?
            Try www.tasauto.com
              doesnt matter jack squat if they are torn. recenter them and fill them with LIQUID polyurethane ud come out spending 36$ shipped for urethane and have all new filled motor mounts with a lil effort and work. that sounds like a saver right there to me
              [COLOR="Magenta"]
                I don't work for Advanced Auto
                When replacing my cousin's F22A4 (automatic transmission), I made him buy a new Rear Motor Mount since his was busted. He gave me money and I picked up a new Rear Motor Mount at Advanced Auto for $68.47. It came with a busted vaccum diaphram, but it was their last unit. I swapped the vaccum diaphram from the OE to the new unit. It worked beautifully, but now you have me wondering if it will last.
                1997 Honda Accord EX-V6:
                Originally posted by James Matteu
                You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
                  I have an awesome 94 Prelude Automatic VTEC Rear Mount/Mount Bracket and mount bolt I'd let go for $35 Shipped
                  The Regular Auto Mount your trying to get is very expensive and breaks easily.
                  This mount is designed to take 200HP
                  It bolts up to any F/H series trannys.
                  Your man for wiring solutions!
                  CB7Man's Coupe H22 Swap
                  CB7Man's Sedan Resurrected From The Dead
                    our Rear engine mount suck. You replace them and they will break again.
                    i would just get ESP mount for $200+ and they will last you forever and ever.
                      The last one that I bought was at Autozone. I believe that it was around $50.00.
                        You will? Because this is the proper forum for such an offer... Wanna delete that? Or should I just ban you for a week?
                          is this easy to do? is there a diy on here?
