ok so i was at the car wash yesterday and i parked and i accidentally left my headlights on.. go to leave and the car wont start (only rapid clicking).. ok so i have a friend try to jump it (no go) so i end up pop starting it to get it home. once im home i try charging the battery and it wont hold a charge ( btw this battery has been acting up) ok so i swap the battery for a brand new one. it starts right up.. let it sit over night and go to start it and it turns over then .. rapid clicking so the battery is dead ( the new one ) so my question is what caused the battery to drain? could my glove box light drain it?
Wont Start Battery Dead BUT WHY?
Originally posted by 93tunerofdacb7 View Postcould my glove box light drain it?
Charge up the battery and check to see if the brake lights stay lit without your foot on the pedal. The brake light switch behind the brake pedal is sometimes the issue.
Other than that, I don't know.
Maybe its time for a new battery.Bisimoto Engineering
1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
2) Email me, robert@bisimoto.com
3) Contact me on AIM, robert@bisimoto.com
Originally posted by 93tunerofdacb7 View Postok so i swap the battery for a brand new one. it starts right up.. let it sit over night and go to start it and it turns over then .. rapid clicking so the battery is dead ( the new one )Originally posted by robert@bisimoto View PostMaybe its time for a new battery.
Originally posted by ikayto View Posti didnt get one and my alternator was the culprit, but good to know for future reference. :
However, it is a lot easier to tune on.
Check the main ground cable from the battery.
Is there anything new you have added to your car recently?
My 5.7 LS1 Holden Ute
Clean your battery terminals. Also you can also put a test light between your car negative and battery negative. If your doors are all shut and it lights up then you probably have something drawing power. start pulling fuses beginning with your radio fuse. If the light shuts off you found your problem.
