I have a 92 lx and when i accelerate the front end vibrates really bad. Does anyone know why it could be doing this.
bad Front End Vibration!!!!
If its the outers, you can basically take where it bolts to the hub and move it. If it moves easy, most likely its bad. With the inners, push it up. If it falls, its also probably bad. Its supposed to stay in position.
Check that axle, too. I just went through this with my friends Neon. He had the replace the axle he put in three months ago.
Some videos to give you a better understanding:
Bad outer:
http://www.youtube.com/watch?v=so0vL...eature=related
Bad inner:
http://www.youtube.com/watch?v=5Mkaa...eature=relatedLast edited by JPsAccordSE; 09-01-2009, 10:22 PM.
The outer and inner are connected. For the outer one, just unbolt it from the hub, loosen the jam nut, and basically unscrew it. For the inner, there is most likely a boot covering it. You need to get that off. After that, just unscrew it from the steering rack. There is probably a special tool for that, but my buddy just used a large adjustable wrench. Probably not the best way to do it, but it worked.
Just know that you will need an alignment after you take everything apart!
