is it ok to run just a header n dowpipe for a while? if not waht can happen?
quick question about header n downpipe
Why are you looking at doing this? You won't have any back pressure so more than likely it's going to rob you of some hp but if it's just to get you to and work to back and not to just be riding around for a couple of days I wouldn't worry about it.Last edited by Brandoncb7; 09-01-2009, 08:38 AM.
Originally posted by Brandoncb7 View PostWhy are you looking at doing this? You won't have any back pressure so more than likely it's going to rob you of some hp but if it's just to get you to and work to back and not to just be riding around for a couple of days I wouldn't worry about it.
It will be loud, and may get you pulled over.
You'll also be dumping exhaust gas out right under you, so carbon monoxide levels could be dangerous. Keep the windows down, and don't sit idling.
Originally posted by deevergote View PostWhy the hell do people keep saying backpressure is necessary? You NEVER want backpressure!
before i got my full system, my stock exhaust was so rotted that it fell off after the cat... then eventually the cat fell off and i was running straight off a flex pipe with a broken flange
it was loud, but not TOOOOO loud. i was just stay in low rpms and steer away from cops. i got pulled over 3 times in 3 days in the same city. they all let me go when i explained that the parts were coming blah blah90 ACCORD EX..<-- MR thread
