5spd. Shifter moves fine when the car is off. When i start the car, the shifter wont budge at all. With the car off i can put it in gear, push clutch in, start it, but then shifter will be stuck in whatever gear it was in.
Shifter won't budge
Originally posted by fatboy1185 View Post5spd. Shifter moves fine when the car is off. When i start the car, the shifter wont budge at all. With the car off i can put it in gear, push clutch in, start it, but then shifter will be stuck in whatever gear it was in.1992 Prelude S w/swapped H22A
Originally posted by benji View PostCheck the fluid level in the clutch master cylinder. Then try bleeding it. If it's still ok, then you are looking at either a clutch master cylinder or a slave cylinder.Need CB7/H22/Turbo parts? i got them..check thread
Originally posted by LeosCB7h22 View Postif its either of those, he will not have clutch PEDAL. it will be stuck to the floor. i agree with the shift fork might being off
Originally posted by fatboy1185 View Postwould the gears still engage when the car is off, even with the fork off?
either the shifter fork is off, or your clutch is completely dead. does the starter try to move the car (or bog down and click) if you try to start it in gear?Last edited by steelbluesleepR; 08-31-2009, 12:40 AM.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Originally posted by steelbluesleepR View Postyes, the clutch fork only actuates the clutch. the shifter cables are a completely different system.
either the shifter fork is off, or your clutch is completely dead. does the started try to move the car (or bog down and click) if you try to start it in gear?
Originally posted by d112crzy View PostMy money is on a completely fubard clutch.
Originally posted by fatboy1185 View Postnope, starts perfectly fine in gear as long as teh clutch is pushed in
When I was doing some T.S. on my accord I found that I could shift 1-3 clutchless with the front tires off the ground (on Jack stands). Just a possible troubleshooting tip.
Other wise I have had honda clutch plates break the springs and then pieces of them get stuck and prevent the clutch from ever disengaging. I have also seen engine mounts brake and put too much tension on shift cables when the engine is running (not allowing engagement).
Originally posted by fatboy1185 View Postthe clutch was never touched.
Try rev matching. Start the car in nuetral, then rev match every gear, in and out.
