I have a 1993 EX coupe 5 speed. I tryed looking up what motor is in it but cant figure out for sure. could anybody tell me? i know this is a stupid question.
Engine Help!
Originally posted by BWhitney View PostI have a 1993 EX coupe 5 speed. I tryed looking up what motor is in it but cant figure out for sure. could anybody tell me? i know this is a stupid question.
if everything is stock...then its for sure a f22...2.2L...if you need like the "a6" or whatever just check the block, it should be left from the exuast manifold...
for the most part, basic modifications won't be any different between the a1, a4, or a6. the only thing big things that come into play are the camshaft (yours being bigger and better than the others), the ecu, and the intake manifold (once again yours being better)90 ACCORD EX..<-- MR thread
Originally posted by MyDianaZ06 View Postlol wow...why won't you check the block?
Originally posted by xaaronx View Postfor the most part, basic modifications won't be any different between the a1, a4, or a6. the only thing big things that come into play are the camshaft (yours being bigger and better than the others), the ecu, and the intake manifold (once again yours being better)
is it different? i had thought the a1 and a6 used the shitty, restrictive cast one while only the a4 had the tubular manifold? not saying you're wrong, that's just what i had thought90 ACCORD EX..<-- MR thread
Originally posted by BWhitney View PostWhat should be the first thing i could upgrade that would make the most difference on my small budget?
you'll see this abbreviation a lot "I/H/E". that stands for intake, header, exhaust. those are the basic first upgrades. you'll get a small but noticeable gain out of them depending on what brand and design you go with. for that, i'll let you go ahead and use the search button. most brands and designs have been covered.90 ACCORD EX..<-- MR thread
Originally posted by xaaronx View Postis it different? i had thought the a1 and a6 used the shitty, restrictive cast one while only the a4 had the tubular manifold? not saying you're wrong, that's just what i had thought
The A4 is the best, followed by the A6, and the worst one is the A1
A1
A4
A6
Originally posted by xaaronx View Postthere are a lot of threads on this but here's a basic guide
Originally posted by AbsurdNY View PostNope I'm not wrong. All 3 are different. The A1 uses a cast "manifold" type, the A4 uses a tubular "header" type, and the A6 uses a cast "header" type.
The A4 is the best, followed by the A6, and the worst one is the A190 ACCORD EX..<-- MR thread
Originally posted by xaaronx View Postoh, word. thanks for correction.
