Friend is driving an 88 civic between austin tx and arizona. She says her speedo has been off since she left here (columbus,Oh). She says her speedo is now dead, and the transmission is havin a hard time changing gears. When she puts it in park or reverse, it sticks. Her boyfriend put one of those big, old school tvs with the speaker at the bottom in it (the car). Any idea what's going on?
dead speedo, CEL?
R. I. P. V S S
From your description, I can tell that your friend has an automatic transmission. The Vehicle Speed Sensor (VSS) is dead. It sends a reference voltage via an Orange wire to the: Cruise Control, Speedometer, and Transmission Control Unit (TCU) (for Automatic Transmissions only). Right now the TCU doesn't know what speed the car is moving at and is having trouble timing the downshifting. I bet the car shifts hard during acceleration and then delays downshifting afterwards, I had the same problem with my C27A4.1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
Originally posted by James Matteu View PostFrom your description, I can tell that your friend has an automatic transmission. The Vehicle Speed Sensor (VSS) is dead. It sends a reference voltage via an Orange wire to the: Cruise Control, Speedometer, and Transmission Control Unit (TCU) (for Automatic Transmissions only). Right now the TCU doesn't know what speed the car is moving at and is having trouble timing the downshifting. I bet the car shifts hard during acceleration and then delays downshifting afterwards, I had the same problem with my C27A4.
92' Ex - Needs work, but hey! It runs safely
91' Lx -Car vs IDIOT.. R.I.P.
RIP 92' Lx... Car vs Concrete.. Car lost.
Originally posted by TypeG View Postanother vote for VSS. later.Bisimoto Engineering
1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
2) Email me, robert@bisimoto.com
3) Contact me on AIM, robert@bisimoto.com
now she says its starting to overheat.. is there any way she can drain some of her coolant out? her idiot of a boyfriend poured alot of water in it.. its more like 80/20 than 50/50... *sigh* all the more reason nobody but me n my dad mess with my car...
She can throw out some water by unscrewing and pulling out the white plastic reservoir next to the radiator. Of course that's only a good idea once she actually has coolant to put in. How was it possible to add water? Is it leaking?
The VSS shouldn't be hard to replace if you can get to a JY. It might even be a standard part you can get from a chain store.
