Installing an Aftermarket Coil- HELP
    Ok. My tach hand was dropping to zero during high speeds in my 90 LX and I determined that it was either the ignitor, coil, or distributor. So, instead of using trial and error, I purchased a new distributor and an aftermarket coil. Now, the original distributor was internal coil. The new one is for external coil applications. I was having trouble starting my car after replacing the parts and i thought that the timing was off. I put the old distributor back on and it started right up. I did some research and I found out that I have to wire up the coil. I've only been able to find info on converting from an internal coil to an external coil using the old distributor. I need to know how to wire up the AEM external coil to my new external coil distributor.
    1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
    2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
    y dont these aftermarkets tell ppl stuff like this??
    SwaggerJacker
      I dunno bro. I also found out that I have to buy the ballast resistor and holding bracket separately.
      I'm just confused as to how to wire everything up using the factory harness.
        So, I guess no one on this entire forum has ever installed an aftermarket coil.
          Plain and simple: the parts distributor sold you the wrong part; get your money back.
          1997 Honda Accord EX-V6:
          C27A4 - 2.7-liter 90º-V6 with SOHC, 24-valves, PGM-Fi
          MPZA - Electronically controlled 4-speed automatic, 1 reverse
          ~170 cu. in. / ~170 ft. lbs. / ~170 whp
          Originally posted by James Matteu
          You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
            Those aftermarket distributors are a bitch to wire up but they make a hell of difference in power
