Fuel question.
    Fuel question.
    i have a 92 and sometimes when i turn the ignition on the fuel pump doesn.t come on, what can cause this,,,
    run your car not your mouth.
    how do you know that it doesn't turn on?
    do you check your fuel pressure?
    or is the car even turning on?
      Main relay.
        You are correct Vegas. I just had this problem.
          In the heat, the main relay is the main culprit. You can replace or repair it (repair only if you have the tools and skills to solder electronics)
          Be sure that it's the fuel pump, and not something in the ignition system. Hot weather can do a number on the igniter and coil as well.
