Slave engages won't get into gear.
    I go pull out to head to work early tonight and my clutch pedal has about an inch of travel, won't go into gear but the slave engages. This happened to me last night but it was hard to get into gear, but would get into gear none the less. Thinking it was just the clutch line getting hot from 3 hours of driving last night, I let it cool down to the same problem, just not going into gear at all.
    If the slave is working, that means the MC is working. Which leaves me with no clutch, throw out bearing, or pilot bearing.
    Any ideas?
    Testing your knowledge and your wits.
    Need 10th anniversary wheel center caps. PM if you have them
    Can you put it in gear when the car isn't running. It could be a damaged shifter fork.
      Car does go into gear engine off now, wouldn't earlier. Checked the linkage, all straight. Turned car on still real hard to get into gear.
        has it been bled? maybe it can't engage enough
          Yeah I'll be bleeding it tomorrow. I haven't had time. Looks like it never has been bled haha
            sounds like you just have to bleed the system . what you could try to do is pump the carp out of it before try to bleed it to get a lil presure back in the pedal then if it stiffens up try to engage gears .
            CB-K for the win !!!!
              Yeah I tried everything. I just wanted to know about common problems that have been recorded on here. Thanks fellas
                Any ideas?
                As said before, multi pump the clutch pedal to build up pressure, and if that makes a difference all you probably need is a line bleeding at the slave cylinder.
                It's possible that your master cylinder is losing its seal and you will need to replace it or rebuild it, in which case after you bleed the lines your clutch pedal function will slowly or rapidly deteriourate again until you replace the master cylinder. Rebuild kits are like $25 and a replacement master cylinder is like $35.
                final option is, you have a pinhole leak in your clutch hydraulic line somewhere. Probably not, but possible.
                  Alright I was planning on putting dye in to check for a small leak but its very highly unlikely. I'll be bleeding it tomorrow and replacing both brake and clutch master cylinders next weekend along with the slave cylinder.
                    If you have compressed air it's easy to rebuilt the slave cylinder and only costs like $12.95. Takes about 10 minutes once the slave is off.
                    use the compressed air to force the piston and gaskets and spring out of the slave cylinder bore so you can replace it with the one in the kit.
                    Wear eye protection and point it away from you and anyone else, it comes out like a bullet.
                      I have this same exzact problem let me know what you did to fix it!
                      On mine I see the slave cyliner pin moving... so I'm not thinking it's that! I will try bleeding it.
                      My guess it the Master cylinder or the fork. In order to drive I have to turn it off at a light put it in gear and start it.. it will creep forward with the clutch full pressed in. then I just have to time it right to shift into the next gear.. the clutch pedal dosen't spring back all the way when you let it out.. any guesses?? sorry didnt mean to thread jack! lol
                        it could be either but your right, probably the master. If the slave cyl is gone you will have clutch fluid leaking all over the slave cyl boot etc.
                        First thing is always to bleed first, that's a good approach. I doubt it is your fork but of course anything is possible.
                          ok thanks.. It dosen't seem like I'm losing any fluid... it's still full. Is there such a thing as a leak but not enough to refill the clutch master?
                            Yes, at least I think so, if you have a small leak. and it's at the top of the hydraulic system. If the master cylinder pushrod is leaking there may be clutch fluid on the pushrod under the clutch pedal.
                            But again, most important thing is bleed the system and see if it gets you anywhere. If you have no bubbles in the system and it still doesn't shift or improve shifting then you would look beyond the clutch hydraulic system to the release fork (is it still on correctly and is it undamaged?) and possibly beyond. One thing you can do while the car is off (preferably with one of the battery terminals disconnected so the radiator fan cannot come on) is manually press on the release fork with a piece of wood or something and see how far it moves, then compare to the movement when the slave cylinder is operating it. Be careful not to mess up the slave cylinder boot while doing this.
                              Ok I tried to bleed it, there were no bubbles that came out, alittle bit of fluid did come out but not alot!~ the pedal still feels like it's lacking alot of pressure. My guess is what you said the clutch master. I will go ahead and replace that is it diffucult? Does it matter what brand to get? also I tried to move the fork with something and couldnt get it to move. maybe I wasnt putting enough force on it.
