Gauge lights don't work at night...
    Could it be a fuse, b/c as well as that, some parts of my center console doesn't light up either...If it isn't a fuse, could there be a way of replacing the bulbs that light them up at night?
    SOLD!--->
    "...Work like a slave, live like a King..."
    I assume they work in the daytime then, your cars biological clock must need fixing.
    1993 Accord EX
    2011 Subaru STi
      when you turn your headlights on do the rear light up??
      Links to my rides :
      1992 Accord EX*
      1990 Accord EX
      1991 Accord SE (4th)
      1991 Accord SE (3rd)
      1991 Accord SE (2ND)
      1991 Accord SE
        Check the 15A Small Light fuse in the Under-Hood Fuse/Relay Block, you may have a blown fuse. If some of the small lights come on, and others do not, you may have blown bulbs. Removing them and examining the filament is the only way to confirm this; you can do this visually (hard on the eyes) or with a multimeter (my preferred method).
        1997 Honda Accord EX-V6:
        Originally posted by James Matteu
        You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
          They don't work during the day time as well, no matter what the situation is
          All my lights work, it's just that the gauge lights don't work at all. I tried turning the little knob behind the steering wheel that makes the lights brighter/dimmer, but to no avail
          Yeah, the small lights, like the ABS, Brake, etc. all work. It's just the rest that light up the tach/speedo @ night do not work
          SOLD!--->
            The "ABS, Brake, etc." are Meter Lights, they are run through the Meter Lights Fuse. I am speaking of the Small Lights Fuse, it's a different circuit. Do as I say, check the Small Lights Fuse.
