Is it possible to do a v6 J32 swap into a cb? I know anything is possible with enough time and money but has anybody done it. Just curious about all this.
J32 Swap???
It has never been done as far as anyone on this forum knows.
But it has been measured, planned out, and there are a few members saying that they're working on it.
EVERYTHING would have to be custom, but it is certainly doable. If you can fab the mounts, axles, wire harnesses, and anything else that has to be changed, then you can do it... or if you can afford to have that done for you. There shouldn't be any significant changes to the car itself to pull it off, though.
K-1 Attack / accord cradle TL J32 transplant
Originally posted by deevergote View PostThere are threads in the technical forum about it. Some of the more knowledgeable members here have gone into considerable detail discussing it.
This may have been discussed already [sorry...newbie here], but has anyone done an engine transplant of a J32A1 TL Acura 3.2 engine & tranny into a 1990 Accord??? more so, ONTO a 1990 Accord cradle!!!! I am building up an Attack K-1 [see link >>> [ attackforums.com ] that is already designed for a donor cradle from this early 90's Accord .... I have a 2003 TL engine/tranny/wiring/ECU/etc. available that I want to use vs. the H22 that has been normally used in this car.... I'm using a 1998 Legend front suspension assembly [w/new coilover setup the Attack is designed for] and want the drive shaft to align correctly, etc. and want to see if anyone has used the TL's mounts on the Accord cradle.......... the OBD-II wiring/mods will not be an issue, as I did a F355 Ferrari kit car conversion using a 1998 Grand Prix 3.8 V6 a few years back [now For Sale here in Denver on craigslist to make room for the Attack project .. ] .... any assistance is appreciated ........... "
Soon to have the first *Bottle Fed Accord* in MI!
Vouch For: fatboy1185
just an FYI ... you should be able to use a lot of the stock parts from the CL just minor modifications would have to be done...
in the process in getting most everything to attempt this... won't have the complete motor but just a mock up... to make sure the axles and motor mounts will be in the right place and a good fitment !! doing this J/Y style !!
DONE ... my J32a1 in an Attack K1
Originally posted by Gold DA9 View Postall you need is money and the mind set to do it. Patience and fabrication skills will also help.
well it is done ....... not that much cash & some fabrication required [mount & frame mods in my case...]; hardest part was determining axle centerline locations.
check out my build pix here>>>>
http://s47.photobucket.com/albums/f1...pyder%20Build/
NSX front calipers on the rear 5-bolt TL hubs, etc.
