Changing brake Rotors
    Originally posted by Leung View Post
    well it turns out i rounded those little SOBs by using the impact gun. ****.
    i'm going to have to go to the PnP and get me a "replacement". that and i ****ed up my passenger caliper. i forgot i had it off and had my brother step on the brake pedal, now the piston is over extended and tore the boot. ****.
    time to put the car on hold again till i can make it out to the PnP.
    oh i've got a Craftsman 50 gallon 160 PSI air compressor, when i bought it it came with a bunch of air tools.
    That sucks dude. Goodluck though!
    Thanks for the suggestion on the air tools!
    Cris P.
      Always use a 6 point socket on those not a 12point.
      They can be undone easily by having someone press the brake pedal while you undo them.
      My 5.7 LS1 Holden Ute
        There is a tool for every job
        I too have rounded these off once in the past. I used a bolt extractor kit.
        1997 Honda Accord EX-V6:
        Originally posted by James Matteu
        You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
          yeah i was using my 6 point 1/2" drive sockets it's just those things were on there so tight.
