squeaky clutch
    squeaky clutch
    seems to be coming from the engine bay, but i haven't really opened the hood and had someone push in the clutch. does it every time i press it in and it's starting to get real annoying haha.
    thoughts, ideas?
    90 ACCORD EX..<-- MR thread
    thoughts, ideas?
    how does the clutch feel. is it spongey? could be air in the slave line..
    (129)Transactions and counting
      feels pretty alright, but i'll try bleeding to be sure. i had a shop replace both slave and master cylinders some time back so maybe they half-assed it
        I have a squeaky master cylinder and it makes noise every time I press in the clutch and release it. But it still works fine.
        I suspect it is squeaky because one of the mounting studs became partially unthreaded (not threaded all the way through the entire width of the master cylinder mounting base/flange, it was only only by maybe 2 or 3 threads) through the base of the master cylinder when I installed it, but I said "whatever" and left it like that because I only noticed after the job was done and I needed to drive the car and there was a good chance it was mounted well enough.
        if you take a look at the master cyl from the engine compartment, you can see the three holes where the studs fit in. The studs should be threaded all the way through the mounting base. If not, that could be the problem.
        *or* just try tightening the mounting nuts on the inside of the car under the clutch pedal. They could be unequal in tension or otherwise loose. That might help the squeaking.
        In my case, I'm thinking the master cyl, is slightly out of alignment and the pedal pressure is causing the piston to want to travel slightly out of square with the bore and the sound is the seal squeaking against the bore. But I've never bothered to try and fix it. (4 years later)
        It could be the slave cylinder in your case as well, but I doubt it. Master cylinder all the way.
          Take it back and make sure they did their job. If not have them do it again and don't pay! Damn cheap skates.
          Bisimoto Engineering
          1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
          2) Email me, robert@bisimoto.com
          3) Contact me on AIM, robert@bisimoto.com
            thanks for the responses, guys. batever, i'm thinking it does have something to do with my master because it sounds kind of close to me. i'll try some things out when i get time.
            and like yours, mine works 100% fine, it's just annoying ha
              All used master cylinders will make that noise. IT does it on my Accord and My civic.
              Testing your knowledge and your wits.
              Need 10th anniversary wheel center caps. PM if you have them
                i got that same noise, kinda bothers me when im driving with no music, but with some music on its fine, but idk its its natural or its some type of defect, might have to take it to my local shop to get it checked out to make sure its not ruining my car.
                Turbo Setup: 100%
                  Don't bother. A squeaky master cylinder can ruin nothing but itself. When it fails you won't be able to shift. But you'll have plenty of warning first. When if fails you just replace it with another one. Done.
                    I have the same problem, doesn't bother me though. My clutch works just fine
                    SOLD!--->
                    "...Work like a slave, live like a King..."
