Originally posted by cloudasc
View Post
Is there any benefit...
Yes its the same one as in the sig, and it runs perfect, other then the noise from the ROD/WRISTPIN KNOCK when it goes over 2600 rpm, gets loudest at 3200, and gets faster as I rev, without any significant loss in power. Oh and the thunk it makes on startup. I parked it to prevent any further damage. I was hoping its because i need my valve-lash adjusted since I just put in brand new Bisi Pro Race Springs when I refurbished the head 3k miles, which was a month ago.Last edited by cloudasc; 08-20-2009, 01:10 PM.
Because its still the original block with 188k miles on it. Half of that investment has just been in shop labor. Its also been a culmination over the last 3 years and 70k miles. Just read my MRT, you'll understand afterwards.Last edited by cloudasc; 08-20-2009, 01:16 PM.
Originally posted by BigBlueVan69 View PostJohnl, raise the compression of the engine with no other mods would be pointless
Originally posted by BigBlueVan69 View PostMaybe with a tune for the compensation of 91 or 93 octane that he would have to be using after the bump in compression, don't just raise the compression of the engine without telling the engine what to do with it.Regards from Oz,
John.
Originally posted by cloudasc View PostIts not about offending the transmission, its about if I upped the compression, the automatic prevents me from tuning the motor properly... but I just learned from Boost_Lee that he originally boosted his auto using "a chipped manual p06, just plugged the tcu in, ran fine, no cel's/codes, on uberdata 1.66" so hope is not lost.
http://www.cb7tuner.com/vbb/showthread.php?t=80996
Bought from: Bisimoto, FuncOvrForm, HondaGuy1212, wed3k, Konigstiger, 1st2run, BillKisme, k-mart, benjerman112
Originally posted by H22artman View Postyou need to read this:
http://www.cb7tuner.com/vbb/showthread.php?t=80996Last edited by cloudasc; 08-20-2009, 10:59 PM.
