I actually have the same issue. When I run the A/C not only does the car strain more during idle but it also boils the coolant. Ive replaced the coolant with a 50/50 mix. Both fans work to my knowledge I will check that this evening. Could it be the radiator cap? I dont think I have a bad headgasket, though that could be a possibility given the fact the previous owner said when it was hot the coolant "evaporated" I automatically assumed he was using straight water, but under investigation found that the coolant was a mix of some kind. Not sure what the issue is, but my F22 has seen better days... GL fixing your issue and if you figure it out LMK.
Engine running hot with A/C on
I had the same issue. I made sure to replace all leaking hoses, replaced thermostat, radiator, and one of my fans (it was spinning, but very slowly).
Now I could idle with the A/C until I run out of gas, and my temp gauage will not even move.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
i know that the problem is solved, but i had a similar problem with a cb a had a while back.
i had taken the car to a radiator shop to repair a crack in the radiator. they put the plug on the condenser fan on BACKWARDS. every time i used the a/c the car would get hot as the fan was blowing hot air on the condenser instead of pulling heat away.
