I was planning to buy some cheap springs on ebay and was wondering if I could get some tips. I know that I have to buy a spring compressor before I change the springs, but do I have to buy anything else before I install the springs? I heard I may need new shocks, but I am not 100% sure. If anyone has done it before please let me know. THANKS!
Coil Over Springs?
You do need new shocks, as your stock shocks will not hold a drop and will eventually blow, which can be dangerous!
If u are on a budget, Gr2's will do.
If not, then go for something better, perhaps Tokico Blues. Nonetheless, this thread has been made several times. There is a "Search" bar at the top of the page. Try searching first before asking and enjoy your stay!
Quality springs aren't all that much more expensive than cheap crap you find on ebay. You'd be much better off buying a reputable brand. Your life rides on your suspension. Don't cheap out there. If you're not willing to put about $500 into your suspension at the very least, you aren't ready to lower your car.
At the very least, get a set of quality springs, which will run you $150-$200, KYB GR2 shocks (which are just stock replacement, but WAY better than old original shocks) for about $200, a QUALITY camber kit (or your tires will be destroyed very quickly) for about $300, and an alignment... about $60. That's about $800... and as cheap as you should ever go on suspension.
