ok so i was installing aftermarket sparco pedals in my cb7 and the clutch and brake pedals went on just fine, but i am having problem with the gas pedal... there is a trapezoidal shaped box that is welded to the bottom of the pedal that acts as the "floor" when you stomp on the pedal and ensures that you acn only push it down so far... the problem is that because of this i cannot reasonably drill holes for the bolts and then put the nuts on because the bolts would to contained within the box (does this make sense?) so i need help or tips from anyone who has installed aftermarket pedals on their cb7 thanks in advance
![1](http://www.cb7tuner.com/smile.gif)
