Will H22 alternator fit my F22???
    Just like it says. Im trying 2 fix my car, and time is of the essence...??? Thanks! And if it does can i use my stock belt? Change the pulleys?
    _____________________________________________
    2 year ASE Certification/Auto Technician Degree completed
    I believe it will, yes. Not 100% certain, but fairly. Swapping pullies would be best, but you could probably get away with just using the belt for whatever pulley has fewer ribs. Just make sure the tension is right, so it doesn't shift.
      yeah it will fit just change the small pulley on the altanator
        Thanks guys! To make a long story short, my car died in a city an hour from my house at 2:30am yesterday, battery light came on, shorty after HID's started to flicker, shut off and soo on... Took about 15-20 minutes before the car would no longer run, fortinately it died RIGHT at my buddys house, so i left it there 2 sleep for the night, But i got to bed at 5:30!!!! So I just got back from swapping out the F for the H alternator. Bolted right up like stock. NO problems. Used the H pulley, it has 1 extra rib, but seemed fine, just put the belt on the inside half. Started up perfect, no belt squeels or anything, 14.5 volts on start-up...
        I appreciate your help, now i know how to take the power steering and alternator off!!! Took just under an hour total, pretty easy. THANKS!
