ok so i got another p13 for my h22 it has a chip in it and it has an xs engineering sticker on the ecu and the only differience when i put it in my car was i don't have a governor now which is because its a usdm ecu mine is a jdm which cuts of at 200km... trying to figure out what the chip is for anyone done more research on xs engineering or know anything about it
xs engineering ecu
XS is good. But the P13 isn't really an ECU that can be chipped. Removing the limiter is about all you can do.
You might want to call XS and see if they actually did chip it... Most companies won't bother with a Prelude or Accord ECU, because you can't do much with them. That's why we use Civic and Integra ECUs.
Honestly, I wouldn't run that ECU until you figure out what was done to it. It could do some serious damage to your motor.
