I have a f22a6. I thought the valve guides were bad because the car would smoke when I started it up. I changed the guides now and realized that the angle of the head does not allow for oil to sit around the guides. If the car sits for a day or so, I can pull the plug in #2 and there is oil on the piston. Not the other cylinders tho. I dont think its teh piston rings because the oil would drain back down...IMO.
My question is, where could the oil be coming from when the car sits? New HG and valve guides and valve cover gaskets are on the car. I pulled the exhaust header and you can see that the oil is coming from #2 cyl.
Any advise is greatly appreciated. I bought a compression tester today so I hope to have numbers up soon.
