ex wont start
    ex wont start
    okay so every now and then, like once or twice every two weeks or so my 92 ex will not turn over. it just tries and tries... eventually if i wait like 5 - 10 minutes after the first try, it'll crank right up but sometimes like today it takes 30 minutes..... i replaced the starter. the guy i bought it from, my brother, said it's been doing this ever since he had it and he's talked to people with the same car who say theirs does the same. he's taken it to a shop and they couldn't find the problem. it'd always crank right up at the shop.
    any ideas?
    sorry for the run ons, i'm a stoner.
    Replace the main relay.
    I was having similar troubles, and that's all it was. They are also known to be problematic in our cars.
      hmm yea fo for the main relay....
      check if theres any cracks in it....
      also check your ignition module
      go get it tested..
      might be over cookin already
      i may be wrong but go ahead
      IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
        A new main relay will cost about $40, you can repair the main relay you have by resoldering all the components (capacitors, resisters, etc) yourself, or by someone who knows how to. Use a desoldering iron or solder wick to remove the old solder (do it one component at a time), and solder the component back on (provided it doesn't looked burned/damaged/unusable).
          i will give my two cents too to main realy, and usualy there is just few broken solders, so there is no any reason pay 40usd for new.
          WTS / WTB
            alright thanks.
            where is the main relay? im not gonna do it myself, i don't have a.. solderer? i just wanna have a peek.
              Originally posted by 93Frost_cb7 View Post
              alright thanks.
              Under the driver side dash. It's above a grey metal plate.
                thanks buddy
                  If you simply buy a new one, it'll take all of about 10 mins to replace.
                  Once that plate is removed, you just unplug the old relay, plug the new one in.
                    It will be underneath the cruise control box, which you'll have to remove in order to get the pgfi main relay. Hardest part is getting yourself under the dash to see, and still be able to use a socket wrench.
