can i?
    can i?
    this might be a noob question for all the cb7 owner i just got in cb7 about a year ago so for i owmed a 93 and 92 cb7 one auto one 5spd if i would change the head on my f22a1 block with a h23 head would it fit with out any problems non vtec?
    QUOTE=ilovethacb7;2164058]this might be a noob question for all the cb7 owner i just got in cb7 about a year ago so for i owmed a 93 and 92 cb7 one auto one 5spd if i would change the head on my f22a1 block with a h23 head would it fit with out any problems non vtec?[/QUOTE]
    well its basiclly a bolt no mods but if i were you i would stay with you f22 head, build the head and all that and you be making more power then the h23, and if you decide to boost it, stick with the f22 head, it flows way much better, good luck!
    ______________________________
    "I ran open header once, it was sooooo loud little kids were running for cover as I was cruising at 2000rpms. That was enough to know I shouldn't floor it."
      well its basiclly a bolt no mods but if i were you i would stay with you f22 head, build the head and all that and you be making more power then the h23, and if you decide to boost it, stick with the f22 head, it flows way much better, good luck! [/QUOTE]
      cuz it has a lil tapping or knocking not loud wat does this mean and is it fixable also how much to build it?
        tappin might be valvetrain
        a slower knocking might be a rod.
        both are fixable but the easiest would be to check the valve lash. that is free.
        I <3 G60.
