93 cluster on a 91
    93 cluster on a 91
    Hi I was wondering if I could use a 93 ex cluster on my 91 ex? is the wiring in the plugs different or is it just plug and play? Thanks
    i'm not sure but your sig is mildly entertaining.
    The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
      yes it should be , are u doing a auto to 5sp swap ? visa versa ?
      -1992 CB7 EX w/H22 [sold 10/09]
      -2005 Legacy GT limited [current]
        There are some differences between the 2. 1 being the 91 has the maintenance required light. The 9293 clusters have the SRS feature. And the different clusters, ie, Denso or Seiki may be wired differently.
        I'm sure there are other differences, someone else feel free to chime in
          my 93 has the maint "light", tab reset by key
          ____
            Both are 5 speed clustrers. and both have maint push key reminder thing. I tried hooking it up and the wires smeem to be incorrect. like when I turn on the head lights the right blinker stays on and other lights come on that arent supposted to. I mean the plugs are the same but may wires are different?
              haha thanks every one seems to get a kick out of it
                check grounds. There is this little cluster of wires (looks almost like a little tan box actually) bolted w/10mm bolt on the pass side under the hood in the middle of the wheel well...well it's really near the battery but up on the wheel well.
                If you remove the bolt and turn on the head lights, the right bumper turn signal comes on (stays on) and the left head light comes on...something like that...and brights won't work and blinkers won't work.
                other then that as long as you matched the wires it should work.
                *your sig made me remember this...when I was messing with my 240 trying to figure out why it wouldn't get power to the fuel pump, I ended up checking even the ignition cyl...wires changed colors from one connector to the other...and didn't match the diagram I had for that car either...pita!!!
                ____
                  I was doing the same damn thing like 3 weeks ago, i said fuck it, and swapped back in my 90-91 cluster. I came across the same damned problems. That blinker would stay on, and my "bright's" indicator was very dimly lit. The wiring doesnt match at all, it will require a rewire.
                  What i did do was remove the "Bezel" from the EX cluster, and installed it in my DX cluster. Looks pretty decent.
                  Originally posted by SE_DynamiK
                  L M F A O !! Here's some advice: if you want to run 14's, don't sit at the light for 3 seconds after it turns green.
                    Make sure the clusters are the same, like Nippon Denso or Nippon Seiki??
                      yeah I might just do what you did, That way i dont feel to bad for blowing 35 bucks at the junk yard lol
