battery relocating???
    i heard of someone using some jumper cable wires when putting there battery to the trunk, so i was wondering is this a bad ideal?
    because i went to napa today and for 10ft of automotive wire it was 5$ a foot.
    Unless you cut the giant alligator clamps and weld/solder/crimp on some terminals, I don't
    recommend this. Save up for a couple weeks and get a kit from Summit Racing or similar. It will include wire, terminals, and a box for 80 bucks.
    Granted you could create the same thing for half the price.
    ^^click it or ticket^^
      That's actually probably the worst way to relocater a battery I've ever heard of. I'm not putting you down, but who ever decided to actually use that idea is pretty retarded. Do it right or don't do it at all. Using a set of jumper cables means that there's a good bit of exposed metal that could short to the frame doing damage to your car's electronics, not to mention what would happen should you accidentally touch both teminals at the same time. They could slip off leaving you stranded, just a bad idea in general.
      Originally posted by 92dm
      I was actually just being a smart ass, and not really contributing to this at all.
      VOUCHES
      Bought from: cb95spd
        i used the kit from summit. its a nice kit. you just need a distribution block or 2 depending on how you wire things up.
        The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
          using jumper cables as a battery relocator? lets see what happens when you hit a hole in the road and that jumper flies off...
            yah the ideal was to just use the wire, not just to connect it hahah that be retarded.
            i dont remember seeing it, but i seen on this forum somewhere someone said they used that and it was alot cheaper so idk haha
            I think ill just save for the kit
              as long as the wire is 2 gauge go for it...
              folks need to learn to read before posting...he said in the first post he wasn't using the clamps just the wire.
              I've seen some skimpy jumper cables so...again..make sure you get the right gauge.
              The only REAL benefit of the kits is the enclosed box some come with. Other than that you could make your own kit MUCH cheaper. Hell even the box could be had for cheaper.
              ____
                you could just get a battery box from autozone for 10 a circuit breaker for 35 and get some 2 gauge wire from sears or something like that, either way do it the right way..
                  MUCH cheaper than the cheapest ebay setup ($75+)
                  I can't find that box on autozone's web site...is it a battery box or is it called something else?
                  ____
                    Do it, it will work. Its not my car.
                    wat?
