Originally posted by DrSzSoLDIeR
View Post
The shop DID NOT ADD OIL!!!
Maybe you have a massive leak...either way they should have noticed before the car left.
Here's what you need to to:
Make sure it's full with oil (to the upper fill mark), park the car in a dry place where you can easily see a leak...OR put a cardboard box under it. Again keep it dry, cardboard shows oil drips pretty well. In 1-2 hours, come back and look for leaks. After this AGAIN make sure it's full...then let it idle for 15 min. Again on a dry place. If STILL no oil then it means there isn't a leak and they didn't fill your oil
See...
You added 4 qrts, your car will hold 4.5 after oc with filter change. This means NO OIL WAS PUT BACK INTO YOUR CAR!!! And it was driven! Now they expect you to DRIVE it to them?
KNOW THIS...so when you go back, you can tell them
"I know for a fact you didn't add oil, I put in 4 qrts to get the oil line to normal, the car only holds 4.5, the filter hold .5. AND It doesn't leak!"
But realistically they need to pay for a tow truck to come get your car, taken to a shop of YOUR choosing, and they also need to pay the mechanic to inspect your engine for damage. They won't pay for a new engine unless the engine is actually damaged...she prolly ain't. But they NEED to pay to have your car checked out, and NOT BY THEM!
