Camshaft!!
    Camshaft!!
    I was looking for a camshaft, to bolt on in my car but i only find F22 engine and I have an F20A5 engine Sohc non-vtec
    Some one who has the same engine?
    a camshaft is not just a bolt on item. maybe you should read farther into it before you do.
    Click to see ride.↓↓
      why don't you teach him then. this IS the beginner's forum right?
        the cam that i think is worth the money is made by Bisemoto but if you decide to put that camshaft in you have to build the head so that it functions properly and safely but then again thats just the reaserch ive done they should have one for the f20 application i think
          I want to put a camshaft to get more power, but i use the car all days so i don't want a racing one
          Do you know a cam for my engine? it's not an F22 it's F20a sohc non-vtec
            i don't really know anything about the F20 engines but have you considered a a regrind? just find another camshaft for your car and send that in as a core which "Delta" will work with and make changes to the lobes.
              Most companies re-grind YOUR camshaft. You send your camshaft in and specify the grind you want, they machine it and send it back to you.
              Delta is an ok company. I sent my F22B DOHC cams into them for a 260 regrind. It was a nice boost but I wanted more. I will most likely go with Bisimoto on my next regrind.
              Here are some sites to check out. I would call them and find out what you have as options with re-grinds.
              http://www.deltacam.com/
              http://www.webcamshafts.com/
              http://crower.com/
              3 CB's gone....
              1 WK Overland....
              Still miss the CB though......maybe one day.
                The F20A head is very similar to the F22A head. I'm quite sure an F22A camshaft would work (check to make sure, but I'm fairly confident in this)
                I would call the fine folks at www.bisimoto.com and ask. Bisi's parts are top-notch, and he is incredibly knowledgeable about the SOHC F series engines. He could most likely tell you exactly what you need, and then sell it to you for a reasonable price.
